BENZ 190E 2.6 IGNITION PROBLEM probably ECU?
Status
Not open for further replies.
valvalval88
Hi!
Performing spark-test I found that the sparks are intermittent - coming in pattern as follows:groups of 3or 4 sparks,pause,3-4 sparks,pause and so on.And all this happens while the engine is cranking pretty good.I replaced spark plugs,HT wires,rotor,distr.cap,ignition coli.As aftermath the engine run as it should for 2 days and then I faced the same problem again.What to suspect next? - Ignition ECU or some sensor ?Or something else?How to check these parts ?
Thanks in advance
Status
