darrenb1707
I have recently purchased a set of 19" alloys for my 2001 CLK 230K Avantgarde. They are 19x8.5 wide with a ET35 offset and were originally supplied with 235x35R19 tyres all round. However when I tried to fit them I found that the fronts fouled the upper control arm bolt. I then got the supplier to refit the fronts with 225x35R19s to reduce the overall rolling radius. This had the desired effect and I am now clearing the control arms with about 5mm. The alloys look great but it has now made me want to lower the car.
I know the Avantgarde runs lower anyway but I want to drop it 60mm with a H&R full kit which I know is a lot. Anyone any experience with H&R kits? Alternatively if 60mm is too much I have also seen GMax kits that have a 40mm drop. Again, any experiences with these would be appreciated.
I've read a few threads that mention that negative camber increases when the car is lowered. Does anyone know roughly how much that would translate to in mm? I'm obviously running quite tight tolerances and I dont want the tyres to foul again if there is even a small change to the camber.
I'm aware that I can purchase the camber correction bolts from MB but there have been some conflicting experiences of these mentioned in the forum. I intend to get a 4 wheel alignment done once its lowered but I would like to know what issues I'm likely to run into.
Any help and advice would be appreciated! Thanks
