MarkCL
- Nov 25, 2006
- Location
- Hampshire
- W211 E320 CDi Avantgarde
Just wanted to let people know my experience of having had some replacement Bilstein shocks & braided brake hoses put on my C43. The existing stock shock units were getting a bit tired as the car has covered just over 100k miles now and so I asked Olly at PCS to look in to some options for me with regard to getting them replaced. Since I wasn't looking for anything that stiffened or lowered things beyond stock there were only two options in the end - stock shocks from the dealer at around £147 ish each or after market Bilstein units for about £90 each. Needless to say I went for the Bilstein solution
Anyway - I'm very pleased to report that the improvment to the ride and handling is very noticeable indeed and I'm well chuffed with the results to say the least The ride over bumpy roads is much improved, feeling much more progressive and controlled now, and the handling is as sharp as a new pin and with no change to the stock ride height etc If anyone is in the same boat as I was then I can heartily recommend the Bilstein solution.
The braided hoses on the brakes have also made an improvement in braking even over the stock set up, with more control using even less effort than normal. Two little changes that have actually improved on an already good set up
If anyone wants more details about either the shocks or hoses then just contact Olly at PCS.
Andy - I think you're supposed to be getting the braided hoses fitted to your C43 soonish and all I can say is that you should be happy with the result
Cheers,
Mark
Cheers,
Mark
