Black Death
Adamki83
Mercedes E-class, 2005, E270CDI (2.7) + 1992 Mercedes 500SL (R129)
Hello all,
My w211 has the dreaded black death i noticed a smell of diesel coming into the cabin took off the engine covers and found cylinder 1 clogged up, ive left pictures at the bottom so you can see what happend, my question is im aware this can be a straight forward DIY job, but has this gone too far for me to do myself??
Any help would be great!
I wouldn't think that's too much for you but always it depends on your mechanical skills and knowledge.
Read up about it and follow instructions to the letter and you should be fine.
Taffy7hfa
Oxford
Loos like you have caught it quite early, which helps.
Adamki83
Adamki83
This is early!? I know some of them look appalling but i thought was quite bad!
Mark A
Aberdeen
58 ML-320CDI.
Just make sure engine is nice and warm before trying to pull the injector And don’t forget to cleaning out the bolt hole before trying to screw a new bolt in.
Taffy7hfa
Oxford
I've seen much worse than that. If you want my advice, stop using it and get it done quickly by an experienced professional who has done it before, if you have a go yourself and it goes wrong you could easily end up in a world of pain. Also worth saying that it if it goes well it may not cost much at all.
good luck ;)
Westheath
South London
The injector has lifted due to the bl::dy useless bolt failing.
Compare the injector rail connecting pipes number 1 is bent up
and the injector is sitting high out of the cylinder head.
So that is more than a straight forward seal replacement.
umblecumbuz
Wales and Gozo
If the injector is part way out, that has made the rest of the job a bit easier - as long as the bolt hole is not stripped.
But clean away all the gunge before any dismantling.
You may just have got away very lightly.
Adamki83
Adamki83
Thanks for all you're advice and help, i'm just still debating weather i just put it into a garage as it wasnt that expensive to get done and i can be quite clumsy when it comes to fiddly stuff :rolleyes:
Can recommend Danny at RSD in Daventry. He's an Audi specialist but he does any work on my cars I don't want to or can't.
Westheath
South London
Threads will be damaged/stripped that's the failure part.
Thanks for all you're advice and help, I'm just still debating weather i just put it into a garage as it wasn't that expensive to get done and i can be quite clumsy when it comes to fiddly stuff :rolleyes:
It will become more expensive as they investigate further unless they have quoted for repairing the bolt hole.
BillyBoy
W213 E400d All Terrain
This is proper Black Death!!
Adamki83
Adamki83
Just had the job done at my local garage, i swear the car feels noticeably quicker and more responsive and better on fuel!
Am i imagining this or am i fooling myself!
Probably placebo effect....
Dan2k7
Middlesbrough
M class
Had the original bolt failed or stripped any threads?
Westheath
South London
You had been loosing compression and fuel from a leaking cylinder.
Adamki83
Adamki83
  • #17
As far as im aware the garage didnt mention that, they did say it needed new bolts but im pretty sure thats standard practice on this job!
Adamki83
Adamki83
  • #18
Westheath
South London
If those pictures you posted in this thread are from your engine,
as already mentioned,
cylinder 1 has popped the injector due to bolt failure,
unless someones attempted to remove the injector already.
