Black spot wheels
tode
NW FRANCE
S350 btec 2011
Does anyone know what the black spots stuck on the rims are for?
I presume all rims have them -- if not, mine are about 1/4 " dia.
turbopete
Spennymoor
harrisis
w203 C-coupe 220Cdi
This sounds vaguely similar to the white spots that were on the steel rims I bought for the winter from MB.
They appeared to be stuck over a casting/weld/injection point that didnt get coated/painted during the finish.
maybe, perhaps
tode
tode
NW FRANCE
S350 btec 2011
As you can see - on each wheel, a black spot. The position has no relation to either the valve or the balance-weight points.
Just can't see why they bother putting them on. :confused:
[/IMG]
hotrodder
'93 320te, '54 ragtop beetle (in bits)
If there's a convention i'll probably get it backwards but it's probably marking the low spot with regards to runout i.e. as round as the wheel may be it won't be perfect. Sometimes there's a dimple on the rim instead of a sticker.
Tyres often have similar marks on them, usually a red dot for runout and yellow for the light spot IIRC. They don't always have them but when there's a choice the tyre fitter is supposed to pay attention (yeah, right!) to the red one. This'd be aligned with the mark on the rim or with the valve if the wheel isn't marked. The yellow spot would normally be aligned with the valve
I think as Hot rodder that they are balance marks to aid the tyre fitter
tode
tode
NW FRANCE
S350 btec 2011
That does seem to be the idea. On further googling, came across this article by Wheelsinmotion, which I found very interesting: TYRE MARKINGS WIM
DIYMAN
Nr. Harrogate
E270cdi/53 plate/2.7l 5cyl.
Maybe the black stick on dots are a colour code to indicate who made the final inspection.
whitenemesis
CLS55 AMG '05
Unless I missed it tode's links are all for tyre markings?
I find the idea of using a stick on dot to mark something as permanent as a weight/dimension deviation a bit temporary? First good rain and competent valet and that dot is history.
I think I'd go with the QA suggestion. IIRC my AMG wheels from Germany had black dots on each rim, until I removed them prior to waxing!
tode
tode
NW FRANCE
S350 btec 2011
Try going through the article, right to the end :D
This article from "Motor" has some interesting stuff, and describes the stick-on markers very well: MOTOR.
As far as rain washing them off, mine are still very firmly in place, and the 2nd hand rims that I recently bought from Germany still have theirs.
I have just waxed over mine. ;)
whitenemesis
CLS55 AMG '05
The article mentions using dimples or stamps, not a sticky dot? Or have I missed it again?
tode
tode
NW FRANCE
S350 btec 2011
Maybe a quick visit to Specsavers ? ;)
"OE tire suppliers are required to
mark a tire’s radial runout high point
and OE wheel makers are required to
mark a wheel’s radial runout low point
This makes it easy for the OEMs to
match-mount tires to wheels from a ra
dial force variation standpoint during
production. In some cases, these mark
are made with paint dots that help ser
vice technicians remount tires down the
road. However, sometimes these mark
are made using temporary stickers
which either fall off or are removed af
ter mounting. This leaves no readily vis
ible reference marks for the tire techni
cian for future service
Like my reply then in post 6 :D
tode
tode
NW FRANCE
S350 btec 2011
Right. :)
But these stick-on ones would seem to me to be designed to help the car maker achieve a perfect tyre mounting, and the customer has to make the best of it if the sticker comes off. :rolleyes:
whitenemesis
CLS55 AMG '05
Thanks tode, appointment made .. :Oops::Oops:
