The mechanism is quite straight forward. The first thing you need to do is check the power feeds into the regulator. It should have an earth, a constant live and a variable switch live.
Assuming you have these, then check the feed out of the regulator. If there isn't one, it's the reg. If you do, it's the motor.
If the switch or constant live are missing then trace backwards - switch, fuse etc
WE HAVE NOW MOVED: 8 Hazel Road, Woolston, SO19 7GB Service, Repairs and remapping service Any queries, please do not hesitate to contactEmail@mbsofsouthampton.co.ukor alternatively you can phone Colin or Dave on 02380 445820, out of hours numbers are 07787913313 or 07907631681.
