Blower regulator
Pollyperkins
Hi there,
I wonder if anyone can give me some advice i own a CL 500 , 1996 N reg and it has just had a 72,000 mile service at a Mercedes garage where i work. However i need a blower regultor as my climate control is not blowing properly, merc can do me a discount price of £155, however i feel it a bit expensive. Does anyone know where to get one, don't mind a second hand one really, or do you think its best to go new. By the way Merc/Bosch have now changed the regulator to a different one (old part No : 9140 010 099, new part No : 9140 010 512... Bosch part numbers.
The Merc part number is 140 821 83 51.
Any help would be appreciated
Thanks Wayne
Check with Arnie Gunner further down the page, Check the number with him as he has one for sale, you will also find info on specialist/ repairing.
Malcolm
Arnie Gunner
Hi Pollyperkins,
Sorry your out of luck I have one but the part number is 210 820 62 10 not alot of use to you I know! this is for a w202 c class, clk slk etc.
Are you sure it is the regulator????, I had this drama last week and went out and bought a regulator and then discovered it was the motor brushes and com were not comunicating properly!. If merc told you this it is probably correct if its a digital climate system as it will be fault coded (apparently). It might be worth a look though.
Arnie
