Blower regulator?
Woody123
C200 1998 2.0
I’m having some problems with my 98 w202 with the manual climate control (the one with the two temperature rolly wheels)
Sometimes the fan still blows gently when the switch is at zero.
Sometimes the fan kind of makes a chattering noise when switched off, but often it’s silent.
Often the fan doesn’t switch on at all, it won’t work upon starting up and then suddenly springs into life mid-drive.
I’ve checked the fuse for any corrosion, cleaned it a bit and put it back in - no results
I’m guessing blower regulator? What does the group think?
As you can imagine, i effing froze today on my way to work as the blower decided it was having a day off!
robparker
Taunton
Either that or the switch unit
W
Woody123
C200 1998 2.0
Thanks guys, ecp don’t seem to stock them so I’ll get one online
RUBBER_UNDIES
2003 w211 E270 177 BHP
Or it could be that the brushes are worn in the heater motor.
Tel: 020 8863 9233
