Blower reset light E200 W210 1999
mick mc carthy
ok i have a strange prob with the air blower in my car, I took the center dash apart today because i wanted to check out one of the roller switchs for the hot / cold i thoug it was going bad but anyways i had to disconnect the cable which supply the whole unit for about 10 minute and then put them all back and fitted everything back to the dash turned on the air all worked fine then turned it off and it aint worked since, i have a red light on the recycle air button and rest is wrote beside it so i'm guessing i have to reset it all some how, ANY ONE GOT A CLUE HOW TO DO THIS, i know if i hole the EC button in for 5 sec i can get the yellow light on the recycle button to flash twice but the air still wont work.
star
Reading
Smart + others :)
try diconnecting the battery for a min, this will cause other problem like window total closure and radio codes but might reset ur heater control. otherwise on the diagnostics i'm affraid.
I hate typing
M
mick mc carthy
I tryed that one earlyer with no luck and i still have to reset the windows but thats no priob, i've been messign with it all day and have got blower to work but once i turn it off it wont come back on and i have no idea how i'm getting it to work in the first place. there must be some sort of reset for it.
star
Reading
Smart + others :)
Far easier to visit a garage to reset faults on dianostics. wont cost alot unless at a MB dealer.
what is the vin number 210--- the next 3 please
M
mick mc carthy
television its 210 035. any help here lads would be great
M
mick mc carthy
ok i got the car in to get the codes read and this is what i got P1491 A/C Pressure too high. ( dont know how this could be because it never worked correctly) and code B1755 (i dont know what this one is for) When we tried to deleted the codes we could not until the engine fan switched off and once it came back on so did the faults has anyone got any ideas. I had a Air Com refill can that i got some time ago and never used but it has a gage to messure the pressure in the systems so i used it when i got back home and the system pressure was over 120psi so i released the pressure ( i know i'm sure i should have but its just way too warm to have no air in the car) so i got the pressure down to what the refill can says is normal but still no air in the car any ideas any one.
jibcl500
Cambridgeshire
CL500,ML55,SLK280
I hope when you released some of the gas you didnt stand there inhaling it!!!!! ****** stuff is leathal.
Look for some local AC people I know a chap that comes to me for my cars, he charges £40 a bash.
jib
