Legoman
anyone else find the blown bulb indicator is a bit tempramental? , mines telling me i have a blown bulb , but i havent. i guess its an earth issue . any common areas people know of?
These thing can only work on current sensing, as JBerks says, one bad holder and the lamp comes on, its quite simple, poor contact, the resistance goes up and the current down. Poor contact holders also generate heat, heat weakens the springs in the holders.
Never use sand paper as that will remove the flash coated nickel. just a non drying switch cleaner.
Bulb filaments do erode away with use and age, a couple of these and the lamp comes on
