"Boing" from rear suspension. C250 Turbodiesel
Guy Greenwell
Tyne&Wear
My C250 Turbodiesel, S reg. fairly regularly gives a "boing" noise from the rear suspension.
The springs seem undamaged and the noise appears as one of the spring coils moves over the edge of the spring seat of the wishbone.
Any suggestions as to why this happens & possible cures would be appreciated.
Many thanks, Guy.
brandwooddixon
Wolverhampton
S63 Coupe 2014
If the spring is catching on anything then I would expect you to be able to see a witness mark where it rubs.
Is it possible that the spring has lost a small section or isn't seated correctly?
FIBAMAN
TYNESIDE
C180,C180,E300TURBO DIESEL
I have had springs break on two occasions, both near the seat, and on cursory inspection all looked ok, until the broken bit jumped out while driving. Try jacking up car so leg extends and examine spring carefully.
David Nock
South Yorks
CLK/2009/320CDI
Apparently breaks in the springs happen mostly right at the ends so Fibaman's suggestion seems very sensible
hmang
as above.
sounds like broken spring....difficult to see on the car.
or drop the suspension arm, remove spring and then put it all back again
