BONNET INSULATION
The Smudger
2006 CLS320, 2009 E320 T, 2003 CLK320 CONV, 1987 260E
Hi all, I am replacing the bonnet insulation on my W124 and am after some advice.
I need to glue it up and obviously the temperature could exceed 140 degrees or higher under there, so want to use the correct adhesive.
Has anyone done this before and which adhesive did you use?
I would be grateful of any help.
Best regards,
Steve.
ajlsl600
france
Investigate high temp silicone.similar to sealant for log burner flues.try a bit of the old material on a primed plate first.
Wearsafoxhat
Sunny Hampshire by the sea
E63 :S213, SL500 :R129 , V220
I used Trim Fix, high temp on my 129 bonnet. It has lasted a few years so far. I used just less than one can.
Bogus
Edinburgh
W124 230E 1992. BMW X3 2.0 d. X drive 2012
Me too. it does say on the tin “ temperature stable to 120 degC”. But I did mine about a year ago and its all holding find so far.
