Gastro
- Aug 27, 2005
- Age
- 81
- Location
- North East Hampshire
- E280 Estate W211 Sept 2007
Well it's happened to me, or to my beautiful W124 E280 1993. They tried to wrench the star off the radiator shell but couldn't manage it and left it hanging pathetically. The good news is that all that had happened is that the central small diameter spring that tensions the star in its cup was hopelessly stretched, but everything else is fine. I've repaired it using a new spring, so now I have a complete sub-assembly which doesn't seem to want to go back in the hole in the rad shell. I can see that it is supposed to go in and then be turned through 90 degrees to lock it, but its clearly quite an interference fit initially and I instinctively don't want to force it. I've read through the extensive posts to the last thread on this subject but my query isn't covered. Can anyone explain how the assembled unit is actually installed in the rad shell?
I've picked up the fact that "friendly" Merc dealers may install them while you wait, but my dealer is distinctly unfriendly, having once told me over the 'phone that they charge £200 to "open the bonnet" before they lay a spanner on it!
I'll be so grateful for some help and guidance. Thanks.
