Boost Pressure Deviation
R
Rustyosul
Tralee Co kerry Ireland
  • #2
I replaceds both egr valves today and the same fault code #p1470 keeps reappearing. Has any1 any suggestions why would this be happening. My car will not rev above 2000revs or go above 80mph!!
John Kerr
Nr Folkestone Kent
W209 CLK 220CDI Sport
I think code 1470 refers to the turbo transducer.If you search the forum you will find a very good thread on it.
BlackC55
South coast
C43
It very much sounds like the vacuum transducer is the problem with those fault codes.
Trace the wastegate actuator vacuum pipe to a small plastic device with an electrical connection underneath and two vacuum pipes on top.
Let us know if it sorts it.
R
Rustyosul
i have replaced the 2 valves but its still showing the same fault code p1470 so it must be a cracked hose but where to start looking is a mystery!
Uncle Benz
West Sussex
Mainly Mercedes
What car are you talking about?? Is it a conventional wastegate turbo, or a VNT??
R
Rustyosul
1999 e220 cdi! i have 2 brand new vacuum transducers! when they r uplugged without driving the car. the same fault is there so i am close!
Uncle Benz
West Sussex
Mainly Mercedes
I think you probably have variable nozzle turbine. The vane ring on these often seizes up, causing boost problems. Locate the actuater on the turbo centre and push it with a screwdriver to see if it moves freely...
Touchy
Registered
Leicester
I have a 220CDI that has had the the LIMP mode coming in at 3000rpm. I Changed the MAFF, still got the problem. I then checked that the TURBO actuator was working by sucking on the pipe, It was OK. I then removed the vac transducer nearest to the turbo. I simply blew through the base hole & covered the 2 top outlets alternately whilst blowing. ! outlet was easy to blow through, the second was somewhat harder. Whilst I was going purple in the face the unit started to click internally making a noise like a relay clicking on & off. At this point I realised that I had managed to remove an obstruction, dont know what though. I then remoned the second transducer (which appears identical to the first) from the other side of the radiator & did the same. What a wonderfull feeling of relief when I went up the A46 from Leicester for a test drive. The car is now driving perfectly & not going into LIMP MODE after reaching 3000rpm. Try it guys you never know!
Regards
Touchy
