no... it is a unit that is electrically powered and sits in the right side of the boot under the coverings.Hello all
Does the boot need air to close the latch
It’s a W221
YesDo you mean full closing (i.e. press the red button and the boot closes) or the soft close (i.e. once it makes contact, it pulls itself down the last bit)
If the first, then as Barry says, mounted in the side of the boot. If the second, I believe it may need air supply to the actual lock - certainly the W220 did.
Yes
just the soft close ,
sorry .I forgot about the red button system
