Boot light fuse blowing- release light permanently on.
simbad
Noticed the red led on my boot release switch on the center console was permanently on. but boot is closed.
Investigated and the boot light was out.
Checked and fuse 5 in the boot fuse box was blown (5 amp)
Replaced it, it blew in a flash.. tried a 10amp- blew again.
Also noticed the rear interior light is not working( presume they are linked) and the indicators do not flash when locking doors.
As an aside, is there a way to set a 'chirp' when remote open/locking the doors?
simbad
  • #2
hmm, might help...
forgot to mention.. car is clk 55 yr 2000
The short will be in one of the things not working ie lampholder or the like you do need a meter to see where the live is going to ground.
Re the bleep should be possible to fit a small siren to the air pump that runs for a few seconds when you lock/unlock.. I have a box of them somewhere
see what I can do, no on second thought you cant join up there, I will think about it.
malcolm
simbad
malcolm
i was told on another forum that the 'chirp' is now illiegal in the UK for new cars- news to me- as it is annoying, but also that if you program the car to the dutch set up, not sure what that means- then the chirp is there !
On the short, the day before i helped someone jump start and on connecting the leads there were quite a few sparks, could it be connected?
igibbsy
good evening i have exactly the same problem with a clk320 year 2001 did you manage to solve your problem if so can you tell me what it was?
