Boot Lock W203- four pin plug wiring from three pin plug
analyst
Hi, I have bought new boot lock for C180 W203 and the new lock has a four pin plug. Old lock had three pin plug with three wires. I wired the 3 wires as they were in the old pin (pin 1,2 3 to pin 1,2,3,4-empty). There is no forth wire to go in the forth pin in the new plug :confused: . Tried but boot release button doesn't work with this configuration. Can anyone please help? Thanks
Dec
Ireland.
W202
The sensible thing to do, if the circumstances permit, is to bring the lock back and exchange for the correct lock, there will be a part number on the original lock.
If returning the lock isn’t possible then someone on hear may be able to help.
Dec
Is the lock motor faulty,,what was the problem before you started
BlackC55
South coast
C43
It is a modified part. Contact the parts dept where you bought it and they will tell you waht to do. The loom has to be modified from memory.
A
analyst
Hi television, the lock motor was fine. The gear inside the lock had broken so the motor was just spinning. The dealership said that the old lock was superseded by a new 4 pin wire plug lock. They sent me the new lock with a new 4 pin plug. My problem now is that there was no document explaining how to wire this 4 pin plug. Old lock only has 3 wires for 3 pin plug. I did an extensive search on internet but didn't find anything.
A
analyst
SOLUTION: :D
3 Pin Plug --> 4 Pin Plug
XXXXXXX --> Pin1 (Empty)
Pin 1 wire --> Pin 2
Pin 2 wire --> Pin 3
Pin 3 wire --> Pin 4
SOLUTION: :D
So this post can now be locked :D:D pleased that it sorted
