craig amg211
hello everybody ive got a real teaser for you here,my boot would not open,remotely or with the handle,i was about to look into it when the right hand licence lamp not working came up on dash,i got a new bulb (festoon type)it still did not work,there is no live at the connecter the other side is earthed ok,the other number plate works ok.to cut a long story short if i leave the bulb out the boot will open with no problem,as soon as i put the bulb in, it stops opening.ive also noticed the boot lighting does not work,ive checked fuses all seem ok but i dont have the card which tells you which fuse is which,it would seem to me to be shorting out somewhere has anyone come across this before,thanks craig
