Bought Myself a CLK 320
DuncanClarke
Greetings
After much searching, I finally found a nice CLK 320. Black (because I didn't want silver) - a 2001 Avantgarde with Command Nav and a host of features.
Immacuate inside, there is a little corrosion on the bonnet panel - and I will take it to MB for a paint check, since I think that it is coming from beneath the paint.
Almost every car that I looked at had similar problems with the paint, so I surmise that this is typical of the model.
Duncan
Its unusual to have rust coming from the back side of the bonnet. In the case of rust blisters, using a powerful magnifying glass you can see if it is untended stone chip damage. If it was coming from the back side there would be marks there as well. When you go to MB that's what they will do.
malcolm
