philharve
- Jan 20, 2005
- Age
- 73
- Location
- Falmouth, Cornwall, United Kingdom
- Website
- go.to
- W202 C230K Auto 2000
Hi All
I was 'advised' following a successful MOT last week that I would probably require a new, rear, nearside disc before the next MOT. In the inspectors view the disc was pitted but not suffiently pitted to effect its braking performance which was spot on. The disc on the opposite hub, which I assume is the same age, is not pitted.
What causes pitting? If the pitting is light, assuming the disc is otherwise in good condition, would a gentle skimming rectify the problem? Or would replacement be the better option? Are discs expensive? Are they easy to fit?
I assume the discs on W202s. like most MBs, are separate from the hub and its a simple 'bolt on' job to replace them?
REGARDS Phil
REGARDS Phil
