brake light fuse E300TD W210
Status
Not open for further replies.
faz
I have had the "bulb failure" warning light on for a few days.
I changed the rear offside brake light bulb which was not illuminating but this did not cure the problem. (the nearside is OK). I swapped the nearside brake light bulb and socket with the defective one and the problem still persisted.
Could it be a problem with the fuse. Are there 2 fuses , one for each brake light and if so where are they ?
Any help apreciated
E300 TD W210 1997
joe bloggs
Rear lamps prone to melt at connection point and connector sinks into plastic, have a close look at the light itself, also clean up holder connection, you might be able to bend the connector out a bit.
F
faz
Yea, I bent out the connector on the bulb holder and this seems to have fixed the problem
THanks Joe !!
Status
