brake pads
aaisha
Bedfordshire
W204/2009/C220
i recently purchased some brake pads and discs from eurocarparts (PAGID) however after 3k miles they are still squeeking like mad everytime i brake, (sounds like a london bus) after speaking to my mechanic he says its the pads they are not good quality can anyone recommend any that they have used and dont have this problem?
Sorry should have said these are on a W204 sport 2009 C220...
whitenemesis
CLS55 AMG '05
I would suggest buying from Mercedes. They are competitive on price and you know they will not squeal
If the pads have been fitted correctly and greased they should not squeal, no well known pad manufacture could stay in business if they all squealed, nothing wrong with Pagid or anything from TMD,,,if they have just been fitted, the one should take it easy for the first 200 miles to allow the gas to escape, it is often a good idea to deglaze the disc when fitting pads, though I never needed to. Squealing can occur for the first few miles, but goes away normally.
I use EBC red and never a problem
Rappey69
hants
c220 w204 amg sport
I recently put in cheap pagid pads and they dont squeel... they came with some sort of fibre backing shim rather than the usual steel ..
Ricardo_e220
Newcastle upon Tyne
R170 SLK230k 1999
Got the same problem with the ones I fitted to my s211 diesel. The discs are fine, won't bother with those pads again.
I normally get recommended ones from my local factor which are often cheaper...
whitenemesis
CLS55 AMG '05
Unless you are using the car for track days I would recommend for normal day to day driving stick with MB supplied pads, they are designed as part of a complete system.
star
Reading
Smart + others :)
I had the same with my Gf's BMW. Some on here recomend them, other don't. I'm in the don't camp.
MERCSPORT
Bedford
2009 CLS 350 CDI Grand Edition
In the previous thread when you were deciding which to use, I said this...
'I am also from Bedfordshire, I am guessing you are getting these quotes from MB Bedford?
I get parts from that dealership, however also use other local dealerships (Milton Keynes, Northampton etc.) to beat that quote.
My own opinion, but on my C180 (Same shape as yours) I have always stuck to the genuine parts and have managed to get very good prices/quotes everytime thanks to this method.'
I have had the same problems with Pagid on my previous C180, I dont like them, I always use genuine parts now on my W204 C180, even the lightbulbs which turned out £2.00 cheaper each bulb than halfords and also it seems that the genuine Mercedes bulbs turned out better with visibility than the halfords ones, I like to think the same with the rest of the car including brake pads and discs.
ZEE
Pathfinder
Gourock
Tear down, grease in the right places, rebuild.
WG M-B
North west london
C63 Wagon in black
Mmm.......
The said pads have been known to cause this
kth286
E320 Coupe 95
some aftermarket pads have been found to have backing plate slightly too
small and therefore too loose in the caliper, and can be the cause of the squeal.
The only thing in the calipers is the slot where the pads slide in, one has to remove the paint so that they slide in easily. Mercedes say grease the pistons and not the pad back, but I still grease the pads both slightly on the ends where they slide in the caliper and the whole rear face.
I have been using some free samples of the TMD copper free grease and never had a problem in years
www.W140.co.uk&www.r129.co
