Brake pedal pulse abs buzz. W211
atlantimd
Ireland
mercedes benz E220 cdi estate W211 facelift 2008. Mercedes SL320 R129 1996.
Hi just wondering has anyone come across this issue. The car has new pads rear and front are good and no warped discs. Intermittently while braking the pedal feels like the ABS is activating and the pedal occasionally pulses back against foot pressure.
I car soft data shows wheel sensor data and driver front looks irregular at times.
Front brakes have that creaking sound when parked and pressed also
That’s for any info on this
Rusty reluctor rings? But I'm aware that not all Mercs seem to use them for their ABS.
Doug1234
Bedfordshire uk
1997 w210 e300td
Metallic pads and ceramic mix , one type front and the other on the rear confusing the ABS due to different pad grip rates.
Have had this on a w210 when I fitted ceramic to the front and had metallic pads on the rear.
atlantimd
atlantimd
Ireland
Can these be cleaned pulling of disc and hub or replacement?
atlantimd
atlantimd
Ireland
Pads are all the same brand and type
Reluctor rings, if fitted tend to tust to the point that they either split or such that the ABS sensor has trouble seeing the indivual teeth. Replacement rings are generally available on the Web.
