brake problem sprinter311 xlwb 04
blaser
hi can anyone help i have just had to change rear pads ,discs for the second time in two months front seem fine , no one seems to be able to help with problem i use her for multidrop deliveries so constant stop start at about 1000 miles a week . there is no self leveling thing and it is all electronic , no lights coming on .rear pads do burn when first put on and smell alot . please anyone got any clues martin
mister_cee333
There's got to be a problem there somewhere. I've now done more than 50k on a set of rear pads in a 02 medium wheel base, mixed multi drop and distance. On mine there's a load sensing valve under the back operated by a hi-tech coat hanger type arrangement. If yours has the same set-up I'd say it's set wrong and the rears are working too hard.
dava
The Toon
Load sensing valve, over rear axle or caliper slides seized but more likely the first as I am assuming it's wearing the pads evenly and a caliper would not. Try pressing the brake or after a run and loosen a bleed niplle, be careful as it's probably under pressure, if it squirts out, then it would point to the load sensing valve. Free off with the usual stuff buy working it back and forth while appling it.
B
blaser
thanks for reply i am new to this i have checked for load senser can not find one apparently there stopped fitting them on that year so i have been told by mercedes dealer orwell trucks calipers are fine. i have just had a thrash in her at high speed and the pads are starting to smell already again after a few miles 5 any other ideas martin
dava
The Toon
Is it the frts or backs thats locking on? When you've got the fault carefully slacken a brake pipe at the master cyl, if it squirts out then there is a hydraulic build up and we are looking at a different fault. Make sure you are sure it's frt or rears as well as both sides as it all fits into forming a picture of what could be wrong.
B
blaser
thanks i will do this tommorow with my friends at ATS where they let me use there equipment. by the way there checked all calipers etc are free and working fine but have not got a clue why she is eating rear pads either . hope to get back to tommorow. martin blaser
B
blaser
hi i loosened front and back no squirts or pressure coming out any more clues martin
dava
The Toon
I realy need more info to work on. Are you sure there is not a limitting valve fitted, just I've looked at ours, 2000 to 07 and they have them, does it feel if it's braking correctly, ie, does it pull up straight does it fell as if it's all rear braking, doe s the abs cut in? Are all rear pads wearing the same way, ie wearing at angles or inners more than outers aswell as sides. Is the pedal excessivley high, is there any travel on it, does it build up as you drive, ie get increasingly higher, is the brakes after a run starting to slow you down? The more info I have the easier it is, fixing it's easier finding out what is wrong is always the hard bit.
B
blaser
maybe i need to check again just to make sure where is the valve martin
