Broken stud removal
One way is to run the engine up to operating temp then use a freezer spray on the stud, the shock could loosen it often something will come out easier if tightened a touch for as it stands the stud is tight in the opposite direction
Malcolm
hmang
Default
heat is good.
lots of heat is better
Suki
Default
Crieky hil, It seems you have had lots of problems...
If you have a piece of stud protruding?
have you tried a stud extractor?
Failing that can you weld to it (be very careful if you do this!!!)?
