I have the bulb out warning light showing on the dash when the side lights are turned on, nothing when they are off. I have checked every single bulb I can find but all are working ok, any ideas?
I had this problem recently. When I removed the number plate bulbs, they were slightly darkened & checking with a meter showed different resistance readings. I fitted 2 new bulbs of the correct wattage and the fault cleared.
