leninsaccountant
- Nov 25, 2023
- 2017 E-Class
I have always wanted a 1980s W124. I've saved for months, and I'm finally in a position to buy one.
I've found one that I have fell in love with. 90k miles. Great condition. But I wanted to get everyone's advice on some potential issues specific to the car.
I have looked up the car's MOT history. It has passed all of its MOTs, but in the advisories section it noted some corrosion
- Oil leak, but not excessive
- Brake hose has slight corrosion to ferrule all pipes front and rear
- Front Brake pipe corroded, covered in grease or other material both sides
- Rear Brake pipe corroded, covered in grease or other material both sides
- Vehicle structure is corroded but structural rigidity is not significantly reduced
- Front Suspension arm corroded but not seriously weakened both sides
- Rear Suspension arm corroded but not seriously weakened both sides
- Shock absorbers has a reduced damping effect all round
- Front Coil spring corroded both sides
- Nearside Front Outer Anti-roll bar pin or bush worn but not resulting in excessive movement
- Central Prop shaft joint worn, but not excessively
Does anyone know how serious these problems are? Is some underside corrosion to be expected given the car was produced in 1987? I am guessing things like coil spring and brake pipe corrosion would not be that expensive to fix if they did develop into a problem, but 'vehicle structure corroded' and 'suspension arm corroded' scare me.
Any advice about all this would be hugely appreciated -- especially from mechanics, DIY mechanics, and W124 owners. Thank you!
