- May 10, 2007
- Location
- Inverness, Highlands, Scotland
- 2000 Range Rover V8 (miss the Benz)
Hi guys, many thanks for the past advice about cruise control.
I haven't been able to remove the rear tyres & replace them with the correct size yet due to other circumstances explained below.
I have just replaced the fan hub assembly and radiator.
Everything is working except that I think I need to bleed the system, but cant find any bleed valves?!
I did ensure the interior heating controls were set at full heat before topping up. I also half filled the radiator and started the engine while topping up the rest of the way to ensure the full system got filled.
It's a 2 litre petrol 97 model year.
I drove it after topping up with coolant and the guage showed normal running temp, but the heating system blew cool, then hot as I accelerated. When I stopped and let it idle the cool air blew out again. This has never happened before and seeing as how I have just changed the radiator....... You can guess the rest.
How do I bleed this system?
