psmart
- Feb 7, 2006
..reading several other members posts regarding the BAS/ESP failure occuring, and the general conclusion was brake switch fitted under the pedal.
For those of us who have Sequentronic, their is another strong possibility which only affects sequentronic models (apparently):
A fault in the brake wiring loom randomly throws up the failure message. It took a fair amount of time to come to this conclusion, Merc-Care (independent specialist in the deepest darkest North ... Leeds!) were perplexed. Eventually feedback pin-pointed the item and a new wiring loom was installed. Problem solved! If not done under warranty, your looking at 400+! (this was 1 year ago, Merc Cares rates have almost doubled since then)!
