Frank
Can anyone help with 13 pin socket wiring for a new 'C' Class coupe.I had a detachable towbar and electrics installed at the factory.The 13 pin socket was only fitted with 10 pins.Pins 10,11 and 12 were ommitted.This is evidently common in German manufactured cars.I have had pins 10 and 11 fitted by the UK dealer but I am not confident that they have wired them correctly.As this car has a multiplexed electrical system, checking out the socket with a multimeter does not make much sense.For example pin 6 for trailer brake lights shows 12v with ignition off,but operates a lighting board correctly.The pins 10 and 11 should be ignition switched live and earth according to the UK standard but the dealer has wired them to an MB data sheet as ignition switched live and permanent live.The car knows when the lighting board is attached even though there is no micro switch on the socket.
