kevinororke
I've got a W202 C Class Estate with drainage problems for the second time. First time the rain water sump at the back of the engine bay and under the windscreen overflowed into the heater fan.The simple near-side non-return valve on the sump drain was blocked and a poke with a bit of wire solved the problem.
This time I noticed that after washing the car water continued to drip out of the near-side sill under the font wheel arch for around 30 mins while the other side dried up within a minute or so. A quick experiment with a watering can confirmed it was not a repeat of the first problem. The sump was draining fine. The problem seem to be within the box section behind the wheel arch. The water drains into this void from the sump and comes out at the end of the sill. I suspect this void is full of debris such as leaves. Any idea how I can get in there ?
Kevin
Kevin
