Martin Bell
My 1993 C220 Sport Auto (Petrol) has started stalling when you stop at road junctions, etc. The car seems to run fine for first few minutes from cold (& on the open road even when hot, although it "pinks" under load & going uphill). The idle also becomes erratic fluctuating between 500-1500 rpm in a cycle when in park, it eventually stalls if held on the brake in drive.
Since the problem started new spark plugs have beem fitted & system checked for obvious air leaks. I think the throttle body has been cleaned but need to confirm this with the independant garage who now suggest taking it to an MB Dealer.
I took it to a friend of a friend who works for a MB dealer & he plugged it into MB diagnostic machine. This seemed inconclusive, he said it would involve lots of time consuming expensive investigation to trace the exact fault. (He also reset & erased ecu memory codes which cured the SRS airbag light which was staying on after a previous job which involved the battery being disconected.)
He suggests cleaning the throttle body/idle speed control actuator which
may help short or long term but says new one is very expensive!
Any ideas on likely fault or where I should take it to be fixed would be much appreciated , the car is undrivable as it is & I need it soon for a trip to SW France in August!
I am based in Epsom, Surrey/SW London.
Martin 1993 C220 Sport
