I have had my recently acquired C220 CDI Avantgarde with sports pack in the garage twice now to correct a steering problem. It pulls to the left quite severely but the first time the garage said the settings were normal and all mercedes pull to the left! The second time it went in, the service manager said they had adjusted the castor angle to try and correct the problem but it steers exactly the same. The steering wheel wants to rotate anticlockwise and you can feel the pressure of this. if you release the steering wheel the car immediatly wanders to the left, admittedly less so when on a road with negative camber. I have researched the effectes of adjusting castor, camber, toe and thrust angles but I have the impression that the mechanics at the garage are using a very trial and error approach to the problem, they haven't mentioned whether or not they have checked to see if the brakes are dragging on the left wheel :???: . Does anyone have any solutions to the problem.
