c class wiper sticking
tcr200
ashtead surrey
merc c 250 td estate
hi i seem to have a sticking wiper it slows/sticks in the upright position on return stroke i have a w202 c class any info would be great cheers terry
Hello and welcome...there is info in the DIY section on how you can lubricate it all,,and you should do it sooner rather than later
T
tcr200
ashtead surrey
thanks
thanks been to thread very usefull info cheers terry
Guy Greenwell
Tyne&Wear
Hi there'
I had the same problem on my C class. The cause is a dry slide on the mechanism at the bottom of the wiper arm.
Carefully prise off the plastic coverat the base of the arm, I cannot remember exactly where the best place to prise it off is but with care it does come off without damage.
You will see a round bar which slides in two bearings, lubricate this with some oil, I used oil with Molyslip added. Check it works ok and replace the plastic cover.
Mine has been fine for 2 years now.
Kind regards, Guy.
C250 Turbodiesel
SL500
T
tcr200
ashtead surrey
hi took off plastic cover cleaned all parts and lubed with silicon spray seems to be better than ever thanks again terry
