C180 2002, Whirring noise at approx 40mph
polardesign
Hi all,
My car has started to make a whirring noise when cruising at 30-40 MPH (Just audable over the radio). It can be heard easier at 30-40 mph but cannot be heard above 45-50. It is not engine related as does not change with revs, even put autobox in neutral and still get the whirring noise. It is quite quiet but perhaps a bearing going.
It does seem to be on one side, seems to be at the front somewhere but no sure
Any ideas or costs
cheers
Wheel bearing will do this, to test jack the front and slowly rotate the wheel If you can detect or feel the balls as you lightly turn the wheel then the bearing has gone, they are very easy to change
P
polardesign
The noise does not appear to be on any side, my original posting was incorrect
hmang
turn off the heater fan and see if the noise goes
With a wheel bearing by opening each side window in turn sometimes helps, but it takes a trained ear to detect
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
could this be the small cooling fan in the light assembly above his head ? weren't there reports of that causing noise on some models ?
P
polardesign
The noise reduces as I slow down then nothing when still.
More audiable when cruising at 30- 40mph, You can hear it when braking as you slow down at round abouts etc
Not notible when on the motor way
Wheel bearings when gone sound like you are running on very coarse tread tyres that start humming at a certain speed and road
P
polardesign
I shall get the weal bearings checked at Kwik Fit, do they normally go in pairs or on there own..
alancee
southampton/ferndown
my last gearbox had the same noise untill it failed ,drive along a long wall or crash barrier so the noise reflects,i did that for a rear wheel bearing and it was actually the front one,noises are difficult to pin piont ,alancee
