mightymerc
- Apr 21, 2007
help please help!!! Anyone who can do a good deed please reply.
I took my car in today to my local mercedes benz dealer in bolton with a number of problems that I reported. My car is the basic of all w202 c class classic 1996.
Problems are:
1) misfiring and hesitatating heavy on different occasions at low speed and in between 1,2 and 3rd gear when downchanging or up shifting. ( spark plugs replaced and 1 x lead replaced all genuine last 2 weeks)
2) constant knocking noise from front drivers side wheel at low speed and over small bumps. balljoints, all arb front replaced last year)
3) engine rattling and ticking noise only in low gear and low speed and when revving in neutral.
4) BRAKE JUDDER FROM NEW DISCS AND PADS RECENTLY FITTED GENUINE
misfiring occured only when recently last fortnight had full service done with genuine spark plugs from dealer, air filter, fuel filter and oil and oil filter change. Local indie noticed engine spluttering after change and he messed withh the wiring looms it sorted out some of the splutter but not all.
Car has been running rough, rich in petrol and exhaust fumes very noticeable lots of complaints from people when start up in cold.
had the cat and rear box replaced 6 months ago just after mot in september but now after that had retest of cat and exhaust but failing miserably on emmisions. had diagnostic check done and it showed no faults to hand. not even the oxygen sensor or lambda sensor perfectly fine and maff sensor.
N.B car runs fine and well on motorway no misfiring, nothing clean as a whistle.
Mercedes said after spending 1 initial hour today they need 3 more hours to investigate and kept my car until monday. Cost £376 + vat £94 per hour * 4 hours. is this right or is the problem a quick fix. they said there are 6 different faults showing on the diagnostics but did not say what. I had enough left it with them cos im having sleepless nights. is this right?
What should I do?
Problems are:
What should I do?
