C180 Coolant warning light
ernstn
The coolant warning light is on, although it ocassionally goes off again. The coolant level has been checked and is fine. The colant sensor has been checked by an auto electrician who tried replacing it without success.
Does anyone know what the problem is?
Ernstn
Had same problem with warning light. try the windscreen washer filler bottle this also has a sensor in that shows as same low water coolant level on dash hope this works :)
E
ernstn
Tried windscreen washer bottle which is okay. I've read that it could be the radiator fan which is the problem.
