c180 Coupe - Wipers?
taffrhys
Hi Guys,
I have a 2003 c180 Coupe, with a small wiper blade problem.
Got in the car one morning, to find they don’t work when you twist the stalk – on any setting. They do however work when you press the button at the end of the stalk, both to wipe the screen and spray the screen wash. All the other functions work find from the stalk – only the twist know for the wipers doesn’t.
I wanted to ask if this could be a relay problem? I thought that perhaps the timer relay might have failed?
It’s worth knowing that I left the stalk on and every now and again, the wipers do come on, but then stop again.
Any help would be great!
Rhys.
Dec
Ireland.
W202
Sounds like a relay problem all right or possibly a problem at the twist switch, cleaning/inspecting the switch on a W202 can be useful, don’t know your car but it will likely be similar.
(W202= C class up to about 2000) (W203= C class after about 2000)
I don’t know where the relay/s are on your car but you could put your VIN number in here… http://www.detali.ru/cat/oem_mb.asp … and follow the links.
Dec
