I am about to change the front discs and pads on my 1998 C180 Estate. The Haynes Manual states that you must also change the caliper bolts and the disc retaining screws when you do this job - however the bolts do not seem that easy to come by, even from the Mercedes dealer!
My local 'fast fit' brake garage explained that you do not need to replace the bolts, but must clean them and then refit with new thread locking compound. This is to stop them shaking loose in use.
Is this advice correct - I do not want to risk it with my brakes!!!
