Does anybody knows if the fuel level sender unit can be calibrated and how? Thanks
F fouskos Active Member Joined Apr 27, 2006 Messages 38 Reaction score 0 Your Mercedes C180/1995/111 May 5, 2006 #1 Does anybody knows if the fuel level sender unit can be calibrated and how? Thanks
television Always remembered RIP Joined Mar 14, 2005 Messages 164,073 Reaction score 368 Age 89 Location Daventry Your Mercedes 2002 SL500, 216 CL500, all fully loaded May 5, 2006 #2 fouskos said: Does anybody knows if the fuel level sender unit can be calibrated and how? Thanks Click to expand... I think that you will find that it is a fixed unit, why do you want to calibrate it Malcolm
OP F fouskos Active Member Joined Apr 27, 2006 Messages 38 Reaction score 0 Your Mercedes C180/1995/111 May 5, 2006 Thread Starter Thread starter #3 I read that the sender can be electronicaly recalibrated in order to fix the usual problems...
television Always remembered RIP Joined Mar 14, 2005 Messages 164,073 Reaction score 368 Age 89 Location Daventry Your Mercedes 2002 SL500, 216 CL500, all fully loaded May 5, 2006 #4 This, if possible could only be done on the instrument cluster, with a MB HHT test set. I will look later in the day. Malcolm
