C180 ignition problems
mrpat
Newcastle under Lyme
W203
Hi all just after some advise got a fault with a Mercedes C180 W203 model.
Put the key in the ignition, key recognised
Switch ignition on, everything works as normal dash lights up all ignition on items work; dash, wipers, indicators, heater etc. etc.
Turn the key to crank, engine starts and runs but nothing inside the vehicle works, just like the ignition is switched off. No dash, wipers, indicators, heater etc.
I know it's my first post on the forum, I've always worked on and owned VAG cars, just trying to help a friend out.
Would greatly appreciate any advise.
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Needs star diags really but my guess front SAM.
Cole or alex will be good on this one.
jib
Mic
Oxfordshire
www.bennettgibbons.co.uk
Hello and welcome......the knowledgeable will no doubt be with you soon.
Mic
I would say ignition switch failing
Mark@RMK
Birmingham
www.replacementmercedeskeys.co.uk
115CDi Vito
What does the key look like outside? Is the case cracked or worn?
Circuit 50 is not being activated because of a break in IR signal more than likely.
If you have more than 1 key then try the other...
M
mrpat
W203
They key has seen better days. It's a bit cracked around the buttons. Only the one key unfortunately.
M
mrpat
W203
Had it on my scanner today, Front sam had:
B1032 Input signal, circuit 15R
B1025 Signal circuit 15
Engine ecu had:
202C CAN massage interuption, recieved from instrument cluster
202B CAN message interruption, recieved from EIS
WG M-B
North west london
C63 Wagon in black
Then the Sam is not getting circuit 15/ 15r. This comes from the eis so I would suspect key or possibly eis
I have had a similar fault where the same thing you are describing would happen, but intermittently whilst driving. That turned out to be the key
omakayd
w203 2004 C230
first off, I know this is an old thread but I have been having trouble finding someone with this exact issue.
I have this problem with a 2004 c230. Car starts and runs but throws the b1032 and b1025 codes in front SAM.
Both key fobs start the car, lock and unlock the doors but the problem is there with both keys.
What is the likelyhood that both keys are bad at once?
Also, pressing the lock/unlock button of the key while it's in the ignition and car is running will make everything work normally again.
It will be fine until you lock the car. Once you unlock and start the car and the issue returns.
Steve@Avantgarde
Bristol/Somerset
C43 AMG PP/NE, SLR McLaren Roadster, SL55 & C32AMG
I would say that you have a fault with the front SAM or a CAN network fault somewhere. Unlikely both keys are duff. You can't guess at this, I would find an indie with STAR diagnosis to help.
omakayd
w203 2004 C230
The issue was a bad key. When both keys were on the same keyring, neither worked correctly. Trying one key at a time while the other was not inside the car at all revealed the bad key.
om613
london
S202 C250TD, S123 240TD
That's unusual. Glad it got sorted.
Did your car have Keyless Go?
