Bernard Rother
- Sep 11, 2007
Hi All, Can anyone shed some light on the following symptoms ? A '94 C180 PMS. No catalytic converter to warm up, no mass air meter, new engine harness. Bosch diagnostics gives all clear on harness. Start vehicle, blip throttle regularly for about 2 minutes and idle speed drops back to 700rpm each time, normal. From a couple of minutes onwards, after blipping the throttle the idle speed settles at 1400rpm for 14 seconds. That will happen at each stop light etc. Fast idle at 1400rpm for 14 sec. before dropping to 700. Switch car off & restart, idle is back to 700rpm for +/- 2 minutes again, thereafter idling at 1400rpm for 14 sec. then down to 700rpm. NOW .... if I switch on the aircon while its at 1400rpm, the idle drops back to 700rpm ... aircon off = idle at 1400rpm for remainder of the two minute cycle.
Bernard.
Bernard.
