I need a new head unit in the c180 1994 do I need to buy a special wiring harness or should the new radio just plug straight into the existing connector blocks?
should just plug in, mine did when i swapped it out for a replacement, if you buy a sony radio they come with adaptors to couple to the older connectors also, probably other makes also do the same
d:class automotive are specialists in automotive interiors and upholstery. From Mercedes and modern cars to custom and classics. Tel: 01483 722923
Email:info@dclass.co.ukWeb:www.dclass.co.uk
