Hi there, I am new to this forum but would really like some advice on a problem I am having with my car.
I have a 'V' plate C180 Sport - it's done an astronomical 280K miles and has been fine up until this point.
A while ago is started to develop two intermitent problems;
1/ sometimes when you turn the key it makes a metalic clicking sound (from the starter) but does not turn over.
I put a new battery and starter on it, and it was still doing it. So I took it to an auto electricians. They replaced the starter control module and also fitted a by-pass switch which can be used when it does this clicking thing. I haven't needed it until today. The fault appears to be back. So to start it now, I have to get someone to hold the key in the cranking position (which makes the clicking noise) and then press the starter by-pass switch. It will start first time like this.
The electrician advised that when you turn the key, it is a 'request to start' which then performs a number of checks before allowing the starter to turn. Clearly there is a problem somewhere that is stopping it from being allowed to start.
So my question is, does anyone know of anything else that cause this? Or have any recommendations on how to fix it?
The electrician thought maybe the ECU was going to give up soon and that they are mega £££ to replace.
2/ the second problem is also intermitent, but it seems to happen if I pull away with too few revs. The car does not stall, but kind of 'hunts'. The tacho bounces between 1000rpm and 1400rpm and the engine does not respond to applying the throttle. You can put your foot flat on the floor and nothing happens, it just continues to hunt like this. If you turn it off and back on, it's usually OK.
Any ideas?
Apologies for such a long winded first post! But I am clutching at straws with this one!
Any ideas?
