C180 Timing
Mark Kennedy
My wife has a C180 1999, with 50k. when she driver is very hard the timimg slips- like it's missing a cylinder. If she stops and restarts it runs fine again, any ideas?
M
jberks
Don't thinks its the timing - its all electronic. I suspect if it starts to run badly, but then a restart solves it, its something causing the ECU to panick. Best to get the fault codes stored in the ECU checked by a specialist - common things are Air mass sensors but a diagnostic will tell you for sure.
pascal
near Dublin
sl320/1999/3.2
As JB says, there is no real adjustment of timing as its all controlled electronicaly.
Have you checked the plugs/leads/dizzy/rotar
