C180K Coupe 2003 - engine ligh problem
gumis
I have a problem with my car. Every few days yellow engine light comes on and then after few engine starts/stops it goes off. I have no idea what the problem is. I though that it was MAF but it wasn't. Its perfectly clean and engine works fine. It usually comes on when Im stuck in traffic.
I asked my friend to read codes stored in car memory:
- P2004 B2/5 HOT FILM MAF SENSOR
- P2029 MIXT. FORMAT SELF ADAPT (FUEL TRIM)
The first one points me to MAF, but I couldn't find anything about the second one. Does anyone know what might be the problem ?
Also I'm looking for good mercedes specialist in nort London, near Enfield - A10.
Thanks or help
BlackC55
South coast
C43
Maf is your problem.
You have a diesel don't you.
I can tell from the fault you have posted. How geeky!
G
gumis
Black... no it's a petrol engine.
67k miles on the clock.
MAF it's clean. I did check it
G
gumis
Would you know what the second code means ? I couldn't find anything about it and what can cause it.
Can I test MAF somehow ? Or that's the only way - replacing it ?
BlackC55
South coast
C43
Replace it. its the only way.
The second code is a consequence of the first.
When the MAF goes down other things try and compensate, change this first
Cheaper from GSF or Bosch, they have the parts number list
G
gumis
Television,
could you post address to bosh on-line shop please.
G
gumis
I have changed MAF sensor (£320) and it didn't help. I'm still getting this light on my instrumental cluster. Every now and then. It's not constatly on. After 4-5 engin starts it goes of and after next couple days (sometimes even a week) the light appears again.
My friend read fault codes for me couple days ago:
P200A
P201C
P2029
Any ideas?
G
gumis
Can anyone help me with this fault codes?
