One of my air pipes that control the aircon flaps inside the dashboard squeks when the unit is on. Seems to get worse when braking or slowing down. Is it a mission to get into the dashboard?
Are you sure its a flap control pipe ? The power regulator on the fan sounds almost identical. My E whistles and the noise seems to alter with movement. I assumed either the fan, or a leaking vacuum pipe. Apparently this is the fan control regulator which is a common fault, but at £100+ I turned the radio up!.
