THE YELLOW LIGHT IS ON WHAT DOES IT MEAN? HOW DO YOU GET IT OFF? THANKS:smile:
ALSO THE WIPERS HAVE A GO SLOW, THEN WORK OK. MAYBE FINE FOR WEEKS THEN START AGAIN
Welcome to the forum.
I Can,t help with the BAS light but the wiper is a common fault, as the mechanism will just need greasing up, can be an expensive if they fail.
Follow this excellent thread posted another member and it tells you step-by-step how and where to grease it up.
Hope it helps keep us posted on how you get on. http://forums.mercedesclub.org.uk/showthread.php?t=26200
Bit more info on the car is needed here. Also, is it just BAS light on, what about ABS/ESP/ASR? Don't panic yet, it may just be an £8 brake light switch
Just the one light (bas) its in yellow. all else ok(not the wiper). Its a c200 s reg if that helps. Im not panicking but my husband is (he will be paying)
Thanks for the info on wiper , will be fixed on monday!
GAD was founded in 2009 where we developed bespoke ECU Remapping software for motorsport clients, moving forward, we have extended to road vehicles for both performance and economy, contact GAD Tuninghttp://www.GADTuning.co.ukto discuss your requirements.
