Hi all,
I was looking for some help with the following problem.
I have a 1994 C200 Elegance fitted with what I think is a Scorpion 918 alarm. The key fob normally enables/disables the alarm and centrally locks/unlocks the doors.
Recently the central locking started playing up. The fob arms and disarms the alarm but sometimes the central locking fails and the doors don't unlock. If I unlock the drivers door with the key I can get in but the engine won't start.
I can get around this by removing the fuse for the central locking, waiting a minute, putting it back. I can then operate the central locking with the key and the engine starts.
Had the local Mercedes Garage check it out and they said that the problem was the central locking pump. £400+ but they are in short supply and I might have to wait weeks.
Anyway I said that I could live without the central locking and could they disable the immobilizer so I could start the car when opening the doors with the key. They said the immobilizer was a function of the alarm and that the Scorpion alarm can be deactivated using a special key in a slot in the glove box. Took a while but I found the key.
So used the key in the glove box to disable the alarm.
Still have the same problem. With the alarm disabled and just using the key to lock and unlock the doors, if the central locking fails to unlock all the doors the car still won't start.
So I removed the fuse for the central locking, locked all the doors manually, came back later, opened the drivers door with the key and the engine wouldn't start. Had to put the fuse for the central locking back in and the engine started.
What I'm thinking is that the engine is immobilized by the central locking and not by the alarm. Could be the vacuum pump operates the starter immobilizer somehow.
Has anyone else had this problem? Or got any idea how the central locking operates the immobilizer.
Thanks in advance.
Thanks in advance.
