C200 cold running problem
6speedmanual
Hi All
On here to ask for some advice.
My car is a:-
Year 2000
S202
C200 PETROL
5speed TipShift AUTOMATIC.
93000 miles
Full service history. Had a B service at 81000 and an A service at 92000.
Very recently <1 week ago, it has developed an odd problem.
It starts from cold fine.
When driving away, it pulls away ok but feels slightly sluggish. It then seems reluctant to change up through the box, but it does eventually go up the gears to 3rd. Then it seems to be limited to 4000rpm and stays in 3rd gear. It feels as if some default/safe mode has cut in.
If I then slow down and stop the car the engine starts to judder (1 mile and about 3 minutes after setting off). (This feels as bit like the judder you would get if one tries to pull away in too high a gear in a manual) However, the revs are still at normal tickover speed c 800rpm.
If the gear selector is then moved to Neutral or Park, the juddering continues. This suggests that the juddering is not caused by the gearbox as there is no drive load on the engine.
Gently increasing engine speed with the accelerator pedal does not seem to clear the judder and the engine feels slow to rev up relative to what would be expected from a prod on the accelerator pedal.
If the engine is then turned OFF and restarted (say) 10 seconds later, the problem has disappeared and the car drives with its normal performance with lively acceleration (relative term as this is a C200) and changes up through the gears normally.
I feel this is some issue with the warm up cycle of the engine and when some parameters are wrong, the ecu is holding back the car's performance.
Can anyone make any suggestions if my initial belief that it lies in the engine management or sensors? Where I should start to look for the cause of this problem and go about fixing it?
I am a competent mechanic at tacking any work but my brain cannot form a telepathic link with a Merc control module:roll:
I look forward to replies.:)
6sm
I too worked it out to be the MAF before I saw craig.douglas had posted the same thing
6speedmanual
Hi Guys
Thanks to you all for your input.
Is it possible to get the engine management system "read" by a diagnostic box eg. StarDiagnosis? Would this confirm the faulty component?
And if I was to try replacing components (eg the MAF meter)......
Do stored faults in the ecu have any effect on the running of the car after a faulty components have been replaced? If yes, I would need to get the memory cleared before I could expect the car to run properly again. If not ( because the ecu recognises that all parameteres are now ok ) it should run fine as soon as the offending sensor or MAF meter has been identified and replaced.
Is it possible to clear out stored faults without StarDiagnosis kit?
Cheers:)
6sm
6speedmanual
Problem solved.
New Mass Flow sensor. :D
£52 including the VAT from GSF :D:D
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
thanks for posting the solution, do you have the website address of that company you mention so that others will know where to look for the part, plus if possible, the part number that you ordered
cheers
anyweb
